hi,
MY FIRST TIME USING ASD 6.1
when i press play every layer i create shakes all over the workface without animating it.
for an example visit this page...
http://www.madglue.com/t1.html
why?
regards,
miki
newbie/animation problem
hi,
no. i'm not using anything.
even on a blank new project, if i press play the layer orientation cross darts around the center position. nothing stays still on the workspace area.
i'm quite certain i configured something wrongly.
i installed it for the first time and did the first tutorial. then it started the problem.
i've since uninstalled and installed on a desk comp. everything is fine.
still, i'd like to solve the problem on comp. #1
any ideas?
any ideas?
- Víctor Paredes
I think you had noisy as default interpolation. You can change that con preferences. Anyway, for your project you should add key for anything (using copy current frame is the bes way to do it, I think) and then select all your keyframes on zero, right click on them and select smooth.
