newbie problem: making fill shape with hole
newbie-a
Post by newbie-a »
hi, i am new to the software, this may sound stupid, i tried to make a fill shape with holes, i follow every step in the user manual but couldn't do it. the furthest i reach is selecting the curve of the exterior shape and the interior one, then the hole just doesn't appear. what did i do wrong?
thanks a lot for your help!
Be sure that the curves are continuous. It is not the first time that you could create two very close points that are not glued.
To verify that you can create the outer shape by selecting ony the external curve (delete it) then repeat the same with the internal. If you can create both as individuals you can create the hole.
Having crosing lines from one side to other of one of the shapes is cause of problems too.
When you create the two shapes make sure you have un-checked "auto fill" on top of the project window.
newbie-a
Post by newbie-a »
thanks a lot, just figured i didn't uncheck the auto fill option. :oops:
Mavent
Post by Mavent »
slowtiger wrote:When you create the two shapes make sure you have un-checked "auto fill" on top of the project window.
Thanks! It's too bad the Manual can't be bothered to explain things like that.
Recently was created a new thread for indexing manual errors and weakness, maybe you would like to share there what you have found:
Issues with the manual? Report here
