Can somebody make a script for multiple layer settings.
For example, if I want to apply some effect like shadow, visibility, add to mask, vector noise etc. on several layers, I must do it one by on layer. It would bi nice to have a script that allow you to apply wanted effect to several layers at once. On shift/ctrl+click selected layers, run settings for all.
Or at least "copy layer settings", "paste layer settings".
Thank you!
multiple layer settings script request
- Víctor Paredes
totally agree. Any setting should be able to be modified on several layers at the same time, including masking and layer blending mode.
Work in progress... maybe you still could have it if it weren't for a last-hour problems... hitchs! CRASHES!!! (That I'm almost sure are not entirely my fault
) that forced to me to change a couple of things, things that I liked a lot in that way-BTW
Well, maybe I'm trying to add more stuff to it that I should and I hope it doesn't get out of my hand but, as far as I can say, I'm almost sure that (at least) masking in AS will never be the same
- toonertime
