I don't have transparency anymore in Anime Studio 5.6 under Windows 7 (64-bit only !?!).
When I want to export a picture as .png file for example, even if I use the default (grey) color or black color in the background, I don't have any transparency !?! (It was OK under Windows XP !)
Could you help me please ???
6R
Windows 7 (64-bit !?!) and no AS transparency
- Víctor Paredes
AS 5.5 had a problem with transparency saving a rendered screen on png. It was a bug and wasn't fixed until version 5.6, if I remember well. Maybe that bug appear again on windows seven.
Fortunately, you can export a single frame as png and mantain the transparency (at least that worked on 5.5). I mean, you go to Export animation and select, for example, export from frame 13 to frame 13.
- Víctor Paredes
p6r wrote:WOW ! Thanks a lot selgin...
It was so hard not to be able anymore to use AS for my projects (with transparency !)
THANKS THANKS THANKS...
6R
