Character Rigging
super8mm
Character Rigging
Post by super8mm »
I thought it would be interesting to a have a thread of character rigs screen caps.
I've been trying different approaches to try to get the best approach to cover all possibilities my character may need to encounter. Everything from cross bones for muscles and scaling, extra bone below the feet for locking, to shoulder controlled bones in the breasts to lift with the shoulder.
This might be helpful to newcomers or give new ideas or just be interesting to see what different rigs look like.
Galbatron
Re: Character Rigging
Post by Galbatron »
[quote="super8mm"]I thought it would be interesting to a have a thread of character rigs screen caps.
I think that's a great idea :)
GalbE
Yes, it's interesting. I'll post some screenshots of my characters soon.
If we could add the anme file it would be great too.
jose1984alberto
Post by jose1984alberto »
it would be interesting to also post the layer ordering, if its not too much to ask...
Lupas Deva
Post by Lupas Deva »
I'm still learning about the bones.
Is there a correlation between the Actual rl spinal column (neck, spine, tail) and anime bone rigging?
Is it optimal to use the exact number of rigged bones vs vertabrae or is it just where it would bend the best?
The Roller-Coaster Monkeys took my Coffee. 0.o
super8mm
Post by super8mm »
You don't need a bone for every vertebra. It's about controlling the shape rather than support.
Take the rib cage for example, doesn't have to be represented with all the ribs as bones but one bone that controls the surface equal to the rib cage is sufficient.
Imago
Post by Imago »
It's very similar to the tecnique I use for my animations.
How do you rig the back hairs to the head?
My problem is: The head is above the body but the back hairs are behind the body. I use switches for the head turn so I can't use one layer for back hairs...
super8mm
Post by super8mm »
I use two bones, one for the head (switch) its parent is the neck, and one for the back hair its parent is the head. The hair is layered lower than the body so it appears behind. In my case since the head bone controls a switch it doesn't affect the hair so they can be together. Otherwise, I would have to place the hair prior to offsetting elsewhere than the head.
