...Import Vector Art Created in a Different Program
BigMouth
Post by BigMouth »
I've created a character in Adobe Illustrator and now I'd like to animate. However, the drawing tools in Anime Studio are a little cumbersome and I'd rather not have to redraw my character... suggestions? What am I doing wrong? What format does the Illustrator file need to be saved as... I saved it as a png but can only import it as a tracing file, which I REALLY don't want to do... any help would be greatly appreciated!!
Save your illustrator as version 8. If you have AS 6 the import will be much better than in previous AS versions.
Anyway, I recommend you try to understand AS drawing tools, they seems to be weird, but when you habituate it's very easy and fast to get desired results.
However, personally I think it's better to draw directly on AS. Drawing for animating is diferent than normal drawing, so the number of points, curvature and position are important.
BigMouth
Post by BigMouth »
selgin wrote:Save your illustrator as version 8. If you have AS 6 the import will be much better than in previous AS versions.
What do you import the file as? Do I go to File Import?
BigMouth wrote:What do you import the file as? Do I go to File Import?
maybe you should try with that...
pd: I'm not sure if AS debut can import illustrator files. I just know AS pro can.
BigMouth
Post by BigMouth »
I have Anime Studio Pro 6.... when I do a file>Import> Image is Grayed out meaning I can't select it...
The character I built is actually very simple... only 13 points... so it should be fairly simple to animate...
Oh, I see, the demo version can't import illustrator files.
