Rotoscopy - problem - help !
notengo
Post by notengo »
Hello im trying to make a rotoscopy, in AS im using 5.6 well the problem is :
i need to copy what i see in the video that goes under the vector shapes
and the problem is for example (im going to animate a man), for the leg i have 2 shapes connected by a line, well it seems imposible to put alpha in this shapes.
Is there a way? or do you know some other way to make a rotoscopy?
pd: i use the two shapes together because otherway in some situations, when the leg is bend it will create holes.
If someone could help ill be very gratefull, thank you :)
The simplest solution would be to use lines, like a pencil test, and fill the shapes when you have finished...
super8mm
Post by super8mm »
What I do is change the Display Quality and uncheck Fills, that way you can see under or view the animation as needed.
Nice avatar :wink:
