No vectors showing/can't add bones, please help!
newbie11
Post by newbie11 »
When I use Anime Studio, no vector points appear, it draws the image, but I can't manipulate it and can't add bones. WTF?
I recommend take a look on the tutorials. It seems a problem which is covered there. If then you still having problems, go back to the forum and we will help you.
newbie11
Post by newbie11 »
i already browsed the software tutorials and help, no dice, it just jumps into using vectors w/o answering my question.
if someone has the answer i would really appreciate it
In Anime Studio, manipulate things (like bones, vector points, etc) is possible after both conditions are satisfied:
1) Have the correct layer selected.
2) Have the correct tool enabled.
Please check both things in your situation. You problem can have several causes and nobody here will give you any proper reply if you don't provide more information (screen shots specially).
newbie11
Post by newbie11 »
The correct layers are selected, and the correct tool is used. In fact, no matter what tool I use it will not convert the path to vectors. Even squares have no little vector boxes!
So, please, show us some screenshots or/and the anme file to see what is going on.
dueyftw
Post by dueyftw »
By any chance are you working with a raster image? AS does not convert raster to vector.
Dale
Mikdog
Post by Mikdog »
Hmm...go to DISPLAY QUALITY near the bottom right, click it and make sure PATHS is checked.
newbie11
Post by newbie11 »
hey, thanks for all the replies
it turns out the boxes for the vectors were there, just invisible, as well as the bones. I think it was a bad CD so i borrowed my friends for the time being and it works fine
