Hi all,
i am new to anime studio pro 6, and have a major problem... i want to import ai files ( vectors ) into anime studio pro 6, i stumbled across a tutorial which stated i would need to convert my saved ai file to illustrator version 8... but when i have anime studio pro 6 open, i try import in the file > import panel, importing illustrator files isn't highlighted and i can't select the option.
Even when i try to use help it shows me how to do it but it still isn't letting me select the option needed to import ai files...
I use a MAC and on the tutorial he uses a pc, is that a problem??? could anyone please assist me with this problem as I design using ai files and really want to bring some of them alive... many thanks
I can't import ai vector files into anime studio pro 6
brrrrrrrrrstickup...
I sometime have this problem that the file import dialog for illustrator files are dimmed, I usually export ill files from Inkscape and if sometimes I forget to write the extension to the file. "ai" and then AS is unable to see that it is an illustrator file. I'm also on mac. Is that the problem?
If so, just add the ai extension to the file and AS will be able to see it.
- Víctor Paredes
I have not been able to import Illustrator 8 files either. But I have been able to import version 5.
joelstoryboards.com - (WinXP SP3, ASP 6.1)
Smoof nickel
Tutorials?
That's wierd I also have a MAC and it brings up the tutorials
Do not evaluate your attempts or your intentions. Instead, evaluate your results.
