Crowd into circus tent.
tonyg
Post by tonyg »
I'm using AS 5.6 and looking to create a short anim of a crowd entering a circus tent.
A little bit like this Disneyshort but a higher angle and much simpler images (circles would do).
I have tried with particles but can't find a way to get them to move towards a single point or area. I did a search and there was talk of a magnet tool but I can't find it so guess it never made AS 5.x.
I then tried vectors images which got closer but was cumbersome, difficult to cycle even when I created an action.
How would you do it?
You could try animating particles outwards and then running the animation in reverse...
wena
Post by wena »
I didn't know you could run in revers, how?
Wena Parry,
South Wales. U.K.
Mikdog
Post by Mikdog »
Instead of fiddling with particles, though jahnocli's idea is pretty ingenious and would probably work with some fiddling (you could have like an expanding particle thing, render it out in Quicktime, reverse it somewhere else in an editing program unless AS lets you reverse movies, and bring it back into AS as a movie).
But my guess is that trying to find an 'easy' way to do it would take more time than just animating every circle going into the tent.
Or, if you don't mind the circles getting slightly smaller as they go in, create all your circles on one layer, or put them all in a group.
Using the SCALE LAYER tool, set a keyframe for when they're about to go in, and then let's say, 4 seconds later, set another keyframe, where the group or layer is scaled down quite a lot. Be sure to set the layer or group origin in the middle of the tent.
This way, you're scaling down all the circles towards a point so it'll look like they're all going into a tent.
Just for fun I tried that particle solution and reverted the result in TVP.
http://www.slowtiger.de/examples/circus.html
The particle settings are there as well. I turned the whole particle layer sideways. I gave two of the seeds moving feet (vertically oriented). The problem with particles is that they overlap - there's no setting available to change this.
Mikdog
Post by Mikdog »
Ha ha ha. That's awesome. "Roll up roll up to see the circus!"
Here's my token thinking:
tonyg
Post by tonyg »
Thanks everybody.
I reckon overlapping will be OK. I'll try making them evenly spaced and the same speed.
Failing that maybe I can do them individually (in blocks) and move one block to the start point of another.
