line
malcolm
line
Post by malcolm »
rogermate
Re: line replace tool
Post by rogermate »
malcolm wrote:When using the line replace tool in ASP, is there a way to say, draw three lines, keep all of them active, move forward 5 frames and draw the same lines in order of how they were drawn? Instead of having to activate each line separately? Can they all stay active and remember which one goes first?
If there isn't, can anyone write a script to express this idea in ASP?
could you rephrase your question. I don't understand it and suspect others don't either. If you have lines drawn, they will remain there 5 frames forward if you haven't changed them.
Also, you could Copy the keyframe from where the lines where drawn to another frame and Paste it there, which would return them to the same state.
