Texture tiling
arfa
Texture tiling
Post by arfa »
This may have already been reported but here is my version:
On a vector layer draw a rectangle.
Fill that shape using "image texture" - select 'tiling.'
Here is a sample file:
http://www.BuddhaMind.info/as/bits/tiling_test.anme
Here is the sample image I used with that file:
Here is the settings window:
Here is the render of an almost 320x240 rectangle:
The exact same process works just fine in 5.6
Rai López
Post by Rai López »
Hello, with the "Select Shape Tool", try to adjust the texture size/angle moving that two red circles in the main window.
BTW, could you try to remove the other one duplicated post, I think it should be easy before somebody reply to it by mistake... THANKS!
