When I'm doing heavy-duty editing in a vector layer, it seems like I'm switching between "G" (point selector) and "T" (translate) a lot. Sometimes, I just want to pick up a point and move it, and I can't if I have a shape selected. For example, I have a shape selected, and I want to move some points. I have to hit "G" first, then click in an open area to deselect it, then "T". Is there another shortcut I'm missing, or a better way to do it?
Thanks.
Selecting points
That was one of the reasons I wrote my Universal Point Tool (which you can find in this post.
http://www.lostmarble.com/forum/viewtopic.php?t=512
It crams the selection, translation, adding, rotating and scaling of points into one tool. In basic use, it works like the translate tool. If you hold down the <CTRL> key you can select new points, either by clicking on them or lassoing them, even if there are other points selected. If you <CTRL> click on a blank area, all points are deselected.
I really do have to put all these things in one easy to find spot.
- Lost Marble
I haven't tried the Universal Point Tool, but given Brian's track record, I bet it's good.
But there's also an easy way to deal with the situation you describe. To deselect all points, just press the enter key. That replaces the steps you described:
-activate group tool
-click on an empty area
-activate point translation tool
Another way is, if you have a Wacom tablet/pen or a three button programmable mouse, assign G and T to buttons on the pen or mouse. On the tablet you can also assign commands such as tools to the programmable buttons at the top of the pad. I've done this, and also use the Popup Menu feature of the Wacom. With this feature you can enter a list of frequently used commands and assign the popup menu to a button on the pen. When you press the assigned button you get a popup menu that has the list of commands, such as Group Selection, Translate, etc., choose one and it changes to the tool you specify.
Jack
Jack
