Effect problem thinghy? (solved)
tijgie8
Post by tijgie8 »
When i tried to import effects on the stage, it displayed a picture with a torn paper in it. You can solve it by installing Quicktime
The "torn paper" symbol indicates that AS can't find an image file you have imported. You have erased it or changed its location (relative to the AS file).
Re-import again.
tijgie8
Post by tijgie8 »
It's standard effect.
Mikdog
Post by Mikdog »
As slow says that torn paper symbol means you've imported a movie or an image that AS has lost the link to. So, double-click the layer of the torn paper, go to the IMAGE tab and double-click SOURCE IMAGE and locate the image/movie.
tijgie8
Post by tijgie8 »
It won't work
F.M.
Post by F.M. »
It could also mean that AS/Moho doesn't recognize the file format you are trying to use. Png and Quicktime are allowed.
"and then Man created god!"
tijgie8
Post by tijgie8 »
That would be pretty dumb to make a standard file which anime studio can't read
F.M.
Post by F.M. »
It would be helpful to someone else who encounters this problem, if you can share how you solved it.
