Lip synch papagayo problem.
jimmypagefan123
Post by jimmypagefan123 »
Well I saved the lip synch file from papagayo, but when I go to the mouth's switch layer, Source Data doesn't show up, Switch Settings does. What am I doing wrong?
Is this for Anime Studio 6?
In the switch tab of the switch layer settings there is a drop down menu for Select audio sync source. In that menu choose Switch data file and then select the .dat file you created with Papagayo.
If there is an audio layer in your document it will also show up in the Select audio sync source menu.
If you choose an audio layer this will use each switch layer from first to last based on the loudness of the audio. Louder is "lower" in the layer order, softer is higher in the order. Very different from using Papagayo dat files.
In Anime Studio 5:
The switch tab of the layer settings has a button to choose a data source. Either a .dat file or an audio file.
