Renedr problems
Naruto
Renedr problems
Post by Naruto »
I have a littel problem when i render my clips in moho it crash on the last render phase but in quicktime it renders complytly it is because i have the k-lite codec install
Lost Marble
Post by Lost Marble »
Sorry, I'm not sure when I understand completely. Are you saying that when you export to QuickTime, Moho works fine unless you use the k-lite codec (whatever that is)?
As a workaround, can you export using another codec and then convert the movie to the k-lite codec?
7feet
Post by 7feet »
It the K-lite codec pack - a bunch of codecs, players, utilities. I've heard it's got some problematic files in there. So much stuff I think some things may interfere with others
Naruto - which specific codec are you using, as K-lite is only a collector, they don't write their own codecs.
I've had some problems with rendering with Xvid causing Moho to crash.
--Brian
Naruto
Post by Naruto »
7feet i have not youse all codecs yet but by xvid mpeg2 it crach
7feet
Post by 7feet »
Try using Divx 5 if you've got it on there, doesn't crash even if the file sizes are not quite as small.
--Brian
cribble
Re: Renedr problems
Post by cribble »
All i can say is get aother codec that doesn't come envolved with the k-lite collection and try again.
--Scott
cribble.net
