Deleting animation from certain bones
GraphicAnime
Post by GraphicAnime »
I wanted to delete animation from a certain bone in the keyframe. How do I delete the keyframe for that particular bone, without deleleting the key animation for all of the bones.
Thanks,
Which version of AS are you using?
If you are using AS 5.6 then click on the settings button on the time line. Check all the "red" or "selected" bone channel check boxes. Click okay. Now select the bone you want to remove the keys for and only that bones keys will show in the "selected bone" channels in the time line. Select those keys and press the delete button in the time line.
If you are using AS 6 or Debut go to preferences and make sure the "consolidate channels" is UNCHECKED (this is checked by default in Debut but no in AS 6 Pro).
Now select the bone to remove the keys. The selected bone channels are automatically shown in the time line. Select the keys and press delete. Make sure you only drag over the selected bone keys. Only those should "highlight" not the ones in the ALL bone channels.
