Cycling issue in Anime Studio Pro 6
Changes in cycle system is very strange and illogical improvement in ASP 6. Basically I cannot use my previous materials done in ASP 5.6 without changing cycles for 1 frame less to make it work in version 6. I was in contact to Smith Micro and what they said: "There was a change in version 6 to address issues with Keyframe Cycling that affected all keyframes that were set to cycle, so that the animation during that cycle is off by one frame compared to version 5. The workaround is to offset the cycling by one frame." Why?! Can I get back the old cycling system? I have no time to make all changes in scenes and actions,I don't understand the logic of this change. And finally every new version of any software must support all previous versions.Why don't they call this new upgrade as a different software then?
- Víctor Paredes
Take a look at this thread
viewtopic.php?p=77382#77382
Now, if you have too much cycles and you can't actualized them by hand, maybe a script which offset all cycles of a document could help. who knows.
