better looking sketch effect
DominiqueBray
Post by DominiqueBray »
Hello
Please, improve the sketch effect, or at least make the old 5.6 sketch effect back, the v6 one is so ugly... :?
I don't like my lines to have a cold, lifeless, too many perfect vectorial look, I prefer trying to make them have an ink or pen look.
Here is something I made with v5.6 :
And something I made with same settings in v6 :
As you can see, it does not look same at all, and the first is better looking. :?
What I hate are these strange cuts :
I do not fully like the old v5.6 neither, because I always find it too much strong, there should be a way to get it even less strong. In the v6, you can't anymore choose its strengh... So, in next version, I would like the sketch effect to be improved so it is better looking result and so we can choose its strengh.
By the way, there is a strange thing... Look :
Here is something I was working on with the v5.6. (a piece of a background from the series Martin Matin)
( By the way, here is the picture without noise and sketch effect :
Image )
When I first tried to import my v5.6 files in v6, I got this :
I managed to finally get this :
which I find quite cute.
The problem is, I can get this quite nice looking stuff in v6 only with the things I made in v5.6 then imported in v6. If I create a layer in v6 and give it exactly same settings, the result is not as good, like I show you at the beggining... :?
Thanks for reading this request. ;)
________
HONDA CB550 HISTORY
Last edited by DominiqueBray on Mon Feb 28, 2011 10:11 pm, edited 1 time in total.
SpaceBoy64
Post by SpaceBoy64 »
I was also hoping for more control over the speed of the noisy lines, noisy fill.
I used this effect to make my characters shiver.
Rai López
Post by Rai López »
Well, I always have been used this shape effect in that (and many other ways) and I'm very sorry/worried knowing someone have decided to simply remove/hide it forever without previous notice... It makes me wonder what "negligible" feature that I used to use will be the next :S, it simply seems not serious... well...
And about that new "Extra Sketchy" feature... it's just not the same thing, nothing to do with it... unfortunatelly.
britneyclap
Post by britneyclap »
If I create a layer in v6 and give it exactly same settings, the result is not as good, like I show you at the beggining... Confused
Me too. I got the same problem with that. I want to more control on the speed of the noisy lines.
regards,
britney
Simulation prêt
Mikdog
Post by Mikdog »
I also want more control over noisy lines. To be able to slow them down, and then to change how often the frames change. Like, maybe I want the change to occur every 2 frames.
Mikdog,
is this what you want? ;)
SpaceBoy64
Genete wrote:Mikdog,
I'm not sure what Mikdog had in mind, but I would like the ability to make it slower, like change once every three or four frames.
Are you animating the number of lines and other attributes there?
It would be nice to be able to make everything look like it was drawn frame by frame.
DominiqueBray
hmm, I forgot this old topic of mine.
Genete, that is very interesting, how did you managed to slow down the noise animation ??? Please tell us.
________
DRUG TEST
Last edited by DominiqueBray on Mon Feb 28, 2011 10:15 pm, edited 1 time in total.
DominiqueBray wrote:hmm, I forgot this old topic of mine.
That's not AS it is Synfig. ;)
SpaceBoy64
That link doesn't work. Is this available elsewhere?
Thanks!
DominiqueBray
Ah ok. I did not looked at Synfig since quite a few years now... I'll check it.
________
Website design
Thanks!
It works for me. Anyway we are moving the host to other place. Luckily the user should see the new host under same domain in the future.
Try this one:
http://synfig.tuxfamily.org
