How do I animate pictures made with Corel Painter?
Shin.J.Type
Backgrounds are no problem, but how would I go about making individual parts for bone rigging?
Thanks
Thanks
Shin.J.Type
Another tip which you might also already know.
It can help if you fade out the edges slightly on your characters, with
opacity going very light in a short length of space. This helps avoid some
artifacts when your pixelated image is animated against a background. I think the problem is called anti-aliasing.
If you find out anything special using the features of version 6 with bitmap characters, please feel free to share here. That's what I have been using.
Shin.J.Type
Export Resolution
One other question I had...
When I initially import .png files, they're pretty huge. When I make the image in Corel Painter, the canvas size is 720 pixels wide by 576 pixels high, with a resolution of 300 pixels per inch. I assume this is all retained when I open the image in GIMP...
Is there an ideal pixel resolution and size for images that will be imported into Anime Studio, like the Winsor character that comes with the program?
Forget resolution. As long as you exchange files within the computer, only the actual dimensions in px count.
The ideal size is the one you want to work with. If your AS project is 720 x 576 px , then a background painting should be of that size, as a minimum. If there's a door painted in the background and you want to zoom in to that, then the door must be of the project size, and the whole background proportionally bigger.
Shin.J.Type
- Víctor Paredes
basically you have to import images bigger than your video output, so when you zoom in something, it won't look pixelated on the final video.Shin.J.Type wrote:Then does any image I import have to be that same size to achieve consistency?
You can import images at different sizes, no problem, because you can scale each one in AS to get the desired general size.
Shin.J.Type
