Help with sound on Linux PLEEZ
TheChewanater
Post by TheChewanater »
Hey, I have Ubuntu Studio on my laptop, and it won't play sound. The sound card (Sigmatel) is recognized, and all the volume levels are turned all the way up, but there's no sound coming out. I even tried using an external USB audio adapter, and NOTHING. It worked fine with Ubuntu Studio 8.04, 8.10, Suse, and Ubuntu 9.10, but not Studio 9.10. Any help would be appreciated! Thx.
rylleman
Post by rylleman »
First of all have you tried starting AS with padsp?
In a terminal just run
padsp /path/to/AS/AnimeStudioPro
It makes A.S. OSS-sound go through the pulse audio-server.
Else there are a few tips here;
viewtopic.php?t=2747.
TheChewanater
There isn't sound with any program, and I'm waiting to get it fixed before I get AS installed (thus it is in the "Other Software" section). How can I use this to make sound play with other programs?
It must be something specific of ubuntustudio 9.10 because as you said it does work with 9.04. If it is a production machine don't go so further. Stick to 9.04, or you're in a hurry with a special version of any program?
I'm on 9.04 and sound works fine on PC and laptop. And don't miss any special feature of new versions :)
rylleman
Post by rylleman »
Ah, sorry, thought you were AS-specific in your question.
You've tried alsa-mixer, pulse-audio settings and all that?
I think you might have better luck if you ask at Ubuntu forums.
TheChewanater
I'll try that, but the problem is that my graphics card doesn't work with 9.04, but it works with Studio 9.04. I tried over and over again, but 9.04 was extremely slow and crashed when I tried to do any complex tasks. Also, I can't figure out how to install Wacom drivers :oops: .
rylle-
I did ask a the Ubuntu forums, but those are so busy that it went by unnoticed. What is this pulse audio thing? I tried alsa-mixer, but I'll have to do a Google search of pulse audio.
etherpictures
Post by etherpictures »
Can you try dropping back to 8.04 LTS.
For a production machine, you might seriously want to consider sticking with the long term support version. (If you need it for work)
I once had a similar issue with sound. It was a long time ago, but I seem to remember seeing that my master volume was maxed out, but the pcm was muted.
Just curious, what's the hardware where you have problems?
Can you trigger the crash doing something in particular?
For wacom see this: https://help.ubuntu.com/community/Wacom
TheChewanater
Yeah, here's how to trigger the crash:
Turn it on.
As for downgrading to 8.04, I don't think that's a good idea. Maybe 8.10, but not 8.04. I'm gonna try reloading and see if it helps for some reason. If not, I might have luck using XP as a host system and running Ubuntu in a virtual machine, though I don't think I can use my graphics card if I do that.
TheChewanater
Update:
I installed XP on my laptop to see if the sound would work on it, since I couldn't figure out what was causing the problem. I didn't.
I opened it up and looked at my sound card only to find that the guy who fixed it didn't solder it properly (mountains- not blobs). So, thanks for your help. I'm gonna solder it myself. Hopefully I won't solder myself.
Solder? To fix a sound card? You are braver than I am! ;)
How do you know if the soldering process itself hasn't already damaged the card? One small crossed connection could have fried it.
TheChewanater
Here it is. It's not microscopically small, so I think I can solder it with out messing it up. I circled the part where it was soldered into a blob instead of a mountain, so it fell off. Sorry about the huge picture, but I still haven't reinstalled Ubuntu and I don't have an image editing program on my Mac (that I know of :)) so I used MS paint, which doesn't use anti-aliasing to resize images.
Ugh! definitively blurred. Good luck with the hardware!
toonertime
Post by toonertime »
there is a new kind of soldering tool
called Coldheat that only solders
on one specific point, everything
else remains cool. I own one
and it really works. I bought
mine at Walgreens.
TheChewanater
Okay, I reinstalled US with out my sound card plugged in, and it still has a SigMatel sound card in the volume options. I thought this was the internal speaker, but that won't play sound either. I tried using a USB adapter I have, but it's not working either. Any idea what the problem could be? Do I need to change the default sound card? I have a feeling fixing the internal sound card won't help...
