Hide Edge Tool
Locked
teotoon
Hide Edge Tool
Post by teotoon »
I think "Hide Edge Tool" is a great tool. It would solve many problems deriving from unchangable layer order. However, it would be handier, if it was animatable. Or is it?
Lost Marble
Post by Lost Marble »
No, it's not animatable. It's not meant to fake out layer ordering, and wouldnt' work well for that, even if it were animatable. the Hide Edge tool is meant to help you create a partial outline around an object without having to create a separate fill and outline.
teotoon
Post by teotoon »
I see. Then, is it possible to add a function for changing the layer order during the animation?
Lost Marble
You can use depth sorting to move layers forward and back. Take a look at Tutorial 16 (in the 4.x manual) for an example of this.
teotoon
Post by teotoon »
Depth sorting works fine v.4, but when I tried it in v.5, I couldn't achieve the same effect. Has something changed in v.5 or am I doing something wrong? Or, worst of all, is it a bug?
Locked
