Key to Characters
Key to Characters
The pre-loaded characters in AS they all are made with 1 vector layer and 1 bone layer. What is the key to getting my own to work as well?
How do I explain?
I'll try to make sense. On 1 vector layer you draw your character. On 1 bone layer, rig your bones to your vector layer and set your bones to region binding. All of the bones move when I need 1 moved and the vector layer gets all messed up. What I thought I could do is use the manual binding tool. I've made characters before but I put the individual limbs with their own bone layer and then put them all in a folder layer which is confusing and takes a long time. I'm just looking for quicker ways to animate.
mkelley wrote:Um, is this a trick question?
http://www.lostmarble.com/moho/manual/t ... index.html
Check the bone parenting. The only reason all of the bones would move is because you are moving the root parent bone of the whole skeleton. Bone offset will keep everything separated enough that bone only control what you want. Or you can manually bind the points.All of the bones move when I need 1 moved and the vector layer gets all messed up.
Thanks
Thanks. I will try those out and see ow they work.
Figured it out
I've been busy, but I've also been working out my problem. It's not quite the way I thought would work, but it's much better.
1:Put each section of the object (arms, legs, body) on it's own vector layer
2:Put them in a bone layer and manually bind the points
3:You then have to set the parent bones and put the one layer in a folder layer
Works perfectly!!
Works perfectly!!
