codec that has alpha?
dueyftw
Post by dueyftw »
Need a video codec that has alpha. I can't get huffyuv to work. I want to export to a movie then import the movie back into AS with the alpha.
Dale
have you tried with quictime millions of colors+?
PNG codec seems to be the only one which preserves alpha. Choose Millions+ of colours.
mkelley
Post by mkelley »
Well, PNG is for stills -- for stills, PSD will also preserve alpha (it's what I use and then I construct sequences inside of Premiere or After Effects).
Not sure if there is any video codec that preserves alpha right now in AS.
Uhm, I definitely have the PNG codec within all other options in my Quicktime settings. You may check again.
dueyftw
Post by dueyftw »
Thanks, did the trick.
I'm using a two pass render. One on a image for eye blinks, mouth movement and expressions. The second for head tums. The underlining bones don't effect the bones on the second pass.
Dale
TheChewanater
Post by TheChewanater »
Just slightly off topic, but is there an avi codec that supports alpha? The video editor I usually use can't import quicktime (well, it might be able to using AviSynth, but I don't know how).
J. Baker
Post by J. Baker »
