Inserting Key Frames for tons of layers.
Sage
Post by Sage »
Ok I am sure this is a script question but does anyone know a way to space out stuff you already did? I need to add a second in the middle of something I already did. Would like to just push it all so many frames over but not sure if there is a way to do this fast.
Thanks for the help on this, you guys have all been great.
Try Macton's cc_shift_layer_keyframes. :wink:
Sage
Post by Sage »
Well see if I can find it, will be the first time I download a scripit too. Just will save time. Does that work for just one layer at a time or does it do everything that is subbed under that layer?
madrobot
Post by madrobot »
Even if it only does one layer at a time,
you should be able to apply it to each
layer with the same setting and get the
result you're after.
I haven't used that particular script
(yet, but i'll be checking it out.)
Write your settings down in case the fields
don't remember your entries.
It does single, sub, and whole document layers.
One warning. These scripts are old, and do have some issues. I did some fixing to this one, but for the life of me, I can't remember where I posted it. I think the original had problems doing vector layer keys as single layers, or something. I fixed that, but there was another small issue.
But it does work, for the most part. :roll:
