Interpolate sub-layers which are GROUPS - doesn't work.
Hi all. I am fairly new to AS.
I am trying to use the switch layer to switch "mouth" group layers. The reason I need to have groups because I need to mask vector layers located within each group.
In each group I have a vector layer for mouth and one vector layer for teeth and I am gonna add a tongue vector layer, it's easier to work with a masked group cause then it's easier
to hide the teeth and the tongue inside the mouth whenever mouth movment accurs. (see the attached image)
The problem that I am having is, I can not use interploate sublayers feature to smoothly transform between groups whenever I use switch.
Is there anyway to make this work?
Thank you.
Try this:
Masking group layer
>lip switch layer
>>lip phoneme
>>lip phoneme
>>lip phoneme
>teeth switch layer
>>teeth phoneme
>>teeth phoneme
etc...
You'd then assign each of these the same dat file or soundtrack, depending on how you are lip-syncing. You'd use each switch layer as you would the layers you're trying to mask, and they'd still be interpolated.
Masking group layer
>lip switch layer
>>lip phoneme
>>lip phoneme
>>lip phoneme
>teeth switch layer
>>teeth phoneme
>>teeth phoneme
etc...
