Inserting frames
jorgy
Inserting frames
Post by jorgy »
This is probably going to be a "duh" moment, but I've been pulling my hair out for several days now. In a large-ish animation, I would like to insert some frames at the beginning, moving everything to the right several seconds.
I can select groups of keyframes and then drag them right in the timeline, but I want to move the entire document.
I have tried using "Rescale Keyframes" and while it works sometimes, it doesn't work if there is an "overlap". For example, I'm starting with frames 1 to 100, and I would like them to become frames 50 to 150. In this instance, I am not able to get this command to work.
Any help would be appreciated. Thanks!
myles
Post by myles »
Hello Jorgy,
just running a very quick test under Windows, it seems to work here (Moho 5.1).
Note: if you're using "rescale entire document", make sure you select that first then set the keyframe numbers, as ticking the "rescale entire document" option may reset some of the numbers in the fields.
Regards, Myles.
-- Groucho Marx
jorgy
Post by jorgy »
Myles, bingo, that was it!
I was hitting that checkbox and the numbers I had input changed. I never noticed! Thanks tons!
