I have just modified this script.
Auto select layer at a group layer with fa_translate_points tool.
Hold <Ctrl+Alt+Shift> to select a vector layer at a group
http://www.mediafire.com/?sharekey=af86 ... f6e8ebb871
Auto select an image and other group layer script available?
Auto select layer at a group layer with Translate point
Well that's a little cheap. You just copied my Select Layer function into the tool where the call to the separate tool use to be. Great that you're trying your hand at lua scripting, but you really should explain that this is a mod of my tool, instead of making it sound new.
I always try to give credit to whose script it is I've modified, especially if they are an active forum member.
For everyone's info, this does the same thing as my Select Layer tools except it doesn't need my tool installed and uses an extra modifier key.
There's something actually new you could script.Auto select an image and other group layer script available?
