Obj Animation
boshibaro
Obj Animation
Post by boshibaro »
What are the various ways you can animate a poser obj file?
-thnx
Rettsu Gooo!
Well you can import it 'as is', but then you can only animated it by warping it with bones. This works pretty good, but you can only manipulate it in the bone layer's 2D plane, although bone scaling does work well. You can also import each part separately. This will allow for animation of these separate layers in actual 3D space.
For the most part 'as is' will work fine, but if you need interaction with some other layer (image, vector, etc) you may need to be able to layer sort these in among you're 3D obj parts.
:wink:
