i noticed that after i have placed a few of the
scripts, like the reverse frames script, in
the script tools file, in AS i get a little box
in the Other section of the tools with a
red X and a question mark. The script is
described but will not run. I have 3 scripts
like this. What am I doing wrong?
script question
- toonertime
- toonertime
- toonertime
Had to look that one up, since I've never used it. But yeah, that's a button script, so you'd add it to the tool list as:
Also, if you're using Windows, scripts that immediately open a dialog will run twice if used as a button. Just cancel the second time it runs.
Note, the '...' can be replaced with any free shortcut key if you want. You can also just drop this into a 'menu' script folder to use it from there (ASPro only).button cc_reverse_layer_keyframes ...
- toonertime
