Sometimes the simplest of all solutions just don't dawn to me. I had already started to post in the "How to" section, when the right idea hit me like a brick.
The problem: I have a clock and want to show the hands progressing really visible second by second, but not smoothly.
The workflow: I set the start and end position of one revolution at frames #1 and #61, interpolation to linear (as should be done with all rotations). Now I needed keys on every frame in between. First I started to insert them in the timeline, one by one. Stupid way to do. That's where I wanted to ask the forum.
The faster way: one finger on the right arrow, one on the mouse with the rotate bones toool selected. Press arrow key, click mouse, and a key appears. Repeat until end.
Select all keys and set them to "step". Rescale Keyframes, from #1 - #61 to #1 - #1501 (this is for 25 fps). Watch your realistic clock.
Ticking clock
- toonertime
jez curyus
I was wondering if you would mind posting the clock
ASP file for us to look at? I think I would learn
more about rotation if I could see the file.
There's really nothing to it. You could experiment yourself, all you need is a layer with 3 bones: root, and 2 rotating ones. Everything else I already wrote.
But OK, here you are: http://www.slowtiger.de/examples/clock.anme.zip
And here's a test with clock and cogwheels:
http://www.slowtiger.de/examples/gear.html
Descripion:
viewtopic.php?p=69706#69706
Descripion:
I guess you could also have a layer with the clock arm and set the origin to where the clock arm turns. Then, set a key at 12:00 and 60 frames later set another key at 12:00. Set the interpolation to linear, and if your project's @ 1 frame per second, the clock should work correctly! I haven't tested this but from what I imagine it should work.
