fiiling the color
anna dd
fiiling the color
Post by anna dd »
hi. i'have just started to develop moho program. i have one problem. it's not a big problem, but still.
i cannot fill the objects with the colour. i can only fill lines around the objects with the colour. it would be more interesting if i could do both of these things, so could anyone explain to me what i'm doing wrong.
[i think that when i have an object i should select it with the help of "create shape", and this is the moment when soimethin goes wrong, because only a line around the object is selected].
thanks.
Hiddicop
Post by Hiddicop »
I think the problem is that your shape has two ends. It has to be connected. If you draw a square or a circle this is done automaticy, but if you're using the freehand tool you should check the "auto close".
If this isn't the problem I don't know. In that case, post a moho-file or a image trat shows us the shape.
