rotate forearm from inside to outside in front of arm
hany rabi3
Post by hany rabi3 »
hi all. i tried this and i found it nice i need your opinion views
i drew arm and forarm in tow separated layers and then rig by 2 bone
but i did few points control
Was there supposed to be a link there for us to check out? :?
hany rabi3
synthsin75 wrote:Was there supposed to be a link there for us to check out?
i am really dont know how to share my sample :?
hany rabi3
i try now to share it
hany rabi3
mkelley
Post by mkelley »
Vern does this technique all the time -- for "my opinion" I think it's okay but something I really don't find all that useful (I work in 3/4 and moving the downstage arm I simply rotate around down and back up and as quick as it comes it's not noticeable. For upstage arm I dupe layers and move forearm forward, which is a similar technique to this, but since it results in the forearm passing in front of the body I don't need to be very precise about it).
I'm pretty sure Vern's technique for this is well documented here (you could do a search if you want). It's even possible it was that technique that you found elsewhere.
hany rabi3
thanks for reply and it is enough for me to find agreement or ok
so that,
i will continue with this till i learn another
could you refer me directly to what vern do,if possible
thanks alot again
