line adjustment
- tiannaidan
line adjustment
I know there is a line adjustment tool for a line that has been already created but I can't see a way of setting the draw tool to a particular width line so I don't have to readjust every line.
- funksmaname
width? if you set your line width in the right pallette where the colour selection etc is when nothing is selected, the changes you make will be the default style for new objects you create - so give that a thickness, and the new lines you create will have that as default.
Also, better way to create a new style, and assign that by default to new actions in the same way as above (but selecting the style in the drop down instead)... that way if you decide the line width is wrong, you edit the style and they will all change for you.
- tiannaidan
line width
if it was a snake it would have bit me,he,he. somehow missed that one thanks!
