Hello,
In my bone rig, I have a switch layer for the eyes. Within the switch layer, I have sub group that contains the layers for the eye (eyelash, iris, etc.). I was going to add another eye layer for a closed eye.
The issue I am having is that when I move the bone layer for the head I the head and the switch layer for the mouth move, the the switch layers for the eyes stay stationary.
Here is the image of the layer layout. http://s204.photobucket.com/albums/bb31 ... hot-01.jpg
I have highlighted in pink of where the eye swtich layers are.
Bone Organization & and subgroups in switch layers
- GraphicAnime
- GraphicAnime
Thanks, after a couple of tries I got it to work.
Is there an order of procedure to bind the layer groups to the bones on the first try.
Sometimes when I select the head bone and then click on one of the switch layers and hit the bind layer button, it does not activate right away.
http://s204.photobucket.com/albums/bb31 ... layers.jpg
- GraphicAnime
Hierarchy Limit to binding layer to bones?
Hi ,
I noticed an issue, or if I'm doing it wrong.
My whole character is under one bone group.
I have the parts of each arm in it's own folder (left arm folder and right arm folder). The bind layer is only active to the main folder group. When I select the vector layer of the arm parts within the Left-Arm folder or Right-Arm folder, the bind layer is not active.
http://s204.photobucket.com/albums/bb31 ... ER-IMG.jpg
Thanks in advance
Thanks in advance
Binding only works between layers which are directly under each other in the hierarchy. This works:
- bone layer
- - vector layer 1
- - group layer 2
- - bone layer 3
The layers 1 - 3 are inside the bone layer, therefor the binding works.
This doesn't work:
- bone layer
- - group layer
- - - vector layer 1
- - - image layer 2
In this case the layers 1 and 2 are not affected by the bone layer. Only the group layer is bound to a bone.
- bone layer
- - vector layer 1
- - group layer 2
- - bone layer 3
This doesn't work:
- bone layer
- - group layer
- - - image layer 2
