Reloading scripts
mkelley
Reloading scripts
Post by mkelley »
Yipes -- I've forgotten how to reload or recompile scripts. I know I can restart AS, but there's a special function key or something that does it as well and tried as I might (and I tried mightily -- about two dozen searches here) I can't find it.
(This is stuff that really ought to be in the help file somewhere -- and if it is *I* can't find it anywhere :>)
rylleman
Post by rylleman »
ctrl+F5
do you refer to control+F5?
mkelley
Post by mkelley »
Thanks, folks (writing this down...)
ggoblin
Re: Reloading scripts
Post by ggoblin »
Ctrl F5 doesn't seem to be working for me in Moho 13.5 ?
Is there another quick way to reload scripts without restarting Moho?
Thanks
Hello,this is an old thread. The shortcut was changed years ago to Ctrl+Alt+Shift+L
ggoblin
Post by ggoblin »
Thank you, works perfectly!
SimplSam
Post by SimplSam »
You an also use Edit > Edit-Keyboard-Shortcuts and search for Reload to set it to a more user-friendly keys combo.
ggoblin
Post by ggoblin »
Great suggestion, thank you.
Tried setting it to F10 but it wouldn't accept it, so ended up with Alt-R (not as short as F10 but better than default).
Personally, I recommend sticking with the default...it's not hard to remember (press all modifier keys + L for load,) and I'm less likely to press it by accident. 😸
SimplSam
Post by SimplSam »
I set mine to ctrl-alt-r - part of the reason was so I could do it easily with just my left hand.
ggoblin
Post by ggoblin »
My laptop keyboard has a Fn and Windows key between the Ctrl and Alt keys making (ctlr-alt-shift-l) a bit fiddly, definitely needing two hands.
Pity it doesn't seem to allow Function keys as user defined shortcut keys. I think it reserves Function keys for itself even though it doesn't use them all. I tried modifying the keyboard shortcut json file directly but that didn't work either.
