FRAME JUMPING
- toonertime
FRAME JUMPING
I am wondering if a script can be made for the
timeline window that will allow moving down the
timeline a set number of frames?
Say you want to make a movement on 2s or 12s
or whatever. You would want to jump from frame
12 to 24 to 36. I am thinking that the tab key would
be logical. You hit the tab, it says how many frames
do you want to be jumping. You punch in X for a unit
and frame movement with the tab key will then be in
those amounts of frames. Control tab would jump
you back those frames.
http://www.mediafire.com/?mrc3gvbt10z
Here you go!
This may not be implemented how you want, but I couldn't think of any other way. Drop these into your AS 'tool' folder.
This tool has a 'Set increment' number that can be set at the top of the workspace. Ctrl+left/right arrows will move the time up/down by that increment.
I'd suggest giving this a shortcut key to make it more useful. To do that, just add 'tool syn_time_skip ...' anywhere you want in the _tool_list.txt found in the AS 'tool' folder. Just change the '...' to what ever free key you want for the shortcut.
Hope that's pretty much what you had in mind.
Here you go!
- toonertime
wow
Gee Mr. Synth
This is an AMAZIHNG support site for AS!
Thank you so much in advance for your
attention to the request!
I haven't downloaded or tested it yet,
but thank you in advance. I will give
you feedback later after i play with it.
THanx so very much!
THanx so very much!
- toonertime
me again
I just installed the script and put your
button in a navigation group I have.
I is a wonderful tool, and the control
arrow system works great!
You the man!
You the man!
- Víctor Paredes
Yes, this could be added to the other tools. It would go in the "onkeydown" function. The tricky part is the key shortcut. It would conflict with the "nudge" points or bones which uses the same key combo (ctrl-arrow). I haven't experimented with this option yet. Will check to see if adding another key (like alt) to the combo would work. Maybe just using totally different keys with ctrl will work as long as it doesn't conflict with system commands.
Yeah Selgin, as long as the ctrl+left/right arrow isn't being used in the tool, you should be able to add the 'Syn_TimeSkip:OnKeyDown(moho, keyEvent)' function under the same function in the tool. Or if it doesn't have an 'OnKeyDown' function, you'll have to create one and add the TimeSkip function. Here's an example of adding it to the LM translate points tool:
I didn't expect this to be all that useful. Glad I wrote it now.
p.s. Vern answered before I could. Personally, I don't use any of the tools' 'nudge' features, so I'd just replace it with this one.
function LM_TranslatePoints:OnKeyDown(moho, keyEvent)
endI didn't expect this to be all that useful. Glad I wrote it now.
- Víctor Paredes
