I am working on a 32 minute animation with a soundtrack. I have four minutes of animation done, and if I export to an avi w/ mpeg4 codec, I get an 8 MB file, or 2 MB/minute. So my 32 minute animation will eventually have a 64 MB image component.
For the audio contribution, my wav file is 168 MB, so the total avi file size should be 232 MB.
When I import the soundtrack and do the export now, I get a file 3.3 GB in size!!!! What is going on??? Is there a secret to doing efficient exports? Or is this a bug related to poor audio handling?
massive export file size
As far as I know AS doesn't "do" anything to the audio. It supports a specific audio format in the application but it is the codec or compression settings that control the size of the final output.
I don't think this is a bug. For a 30 minute animation you probably should do the final export or compression in a separate application. For instance, out put image sequences, load the sequences into something else, drop in the sound and THEN export.
Compression is based on motion. That 4 minute sample might not be accurate for the whole animation. A 4 minute scene of a simple talking head will be much smaller than a 4 minute action sequence. Lots of motion means a larger size.
You said you imported the ENTIRE audio and exported?
