Matrix Text Effect
Matrix Text Effect
Is it possible to make a matrix text animation in anime studio's particle effect? I've been using anime studio for only three years now so I'm not a complete expert. And by the text effects I mean like the following URL:
http://www.flashperfection.com/tutorial ... 23525.html
The url above goes to a flash tutorial, but I'm just using it as an example.
Piece of cake. I did this in like three minutes using an image string of letters.
http://www.mediafire.com/?iixnzjsdinv
cool dude, thanks. There are like three things I'm still searching for. Remember that URL I put at the top? Well I've been trying to figure out what makes the matrix effect look like the matrix effect. There are a few things that your animation needs:
1.) when the words are coming down they need to fade from the top to the bottom
2.) Is that a mask effect? When the words go down they dissapear from top to bottom, but not fade.
3.) Are the words going down in a pattern, or are they going down randomly?
4.) The words aren't bright enough
5.) The words, as they come down, look like they lag or something. I'm not really sure what hte correct term is, but if you compare the two matrix text effects, the URL and your's, you can notice that the speed is different.
Thanks for submiting though, I appreciate it.
Otherwise it is a great animation that is very inspirational. I noticed you used the same words, but that can be easily fixed by making at least 10 different word streams and sending them down rapidly instead. The ocapacity on the words needs to be a little bit lower, to about 90 or 95%. And lasty: well done. Really inspirational. (Oh and ps: in the tutorials for anime studio [pro if you have it] tutorial 2.6_3 shows that in a mask if you make it wide enough and and blur it, it will look like it's fading out from a certain direction [or in]). Really nice job.
Cool. This is a really helpful file. I think the problem with the whole thing is that you used a different program to make tthe text, if you used anime studio, typed random letters and rearranged them from top to bottom, you could have done much more, and I bet that it would look better. Just one last thing now: Can you fade things out with a particle? Like I said earlier:
-SJHooks
Is it possible to do so using a particle? Please correct me if I'm wrong, but can't you take the singe vector layer used as the base of the particle and make that fade out over time, so that the particle words also do so?1.) when the words are coming down they need to fade from the top to the bottom
-SJHooks
I suggest to have a particle(s) of the entire alphabet switch ('0', '1', ...'A','B', ... 'a','b',...) inside a particle layer that makes the matrix effect. The particle inside would give random letters and the particle outside would place them randomly in the horizontal. Then animate them vertically and with random fading and masking effects.
A little messy but can work
Re: Matrix Text Effect
Sorry to bring this up again after 5 (!!) years, but if someone has an AS file on this that he can share, I'd be very, very thankful.
I'm currently preparing some videos and I'd like the intro to have this background effect.
Wow, I haven't been on this forum for quite some time, but luckily my email still sends me notifications. Sure brings back memories.
Anyways, I do have an old attempt that I gave at the matrix text effect, so I can provide that (rendering took forever though): http://www.mediafire.com/download/s7d7b ... ffect.anme
It's an old Anime Studio Pro 5 file, so I'm sorry if it doesn't work with more up to date versions of anime studio. Basically, I created a vector layer for each letter of the alphabet, all stashed in a particle folder. I set the whole thing up so that the letters would fly out, single file, evenly spaced, at random, etc. I put that particle folder into another group folder, and created an animated, looping mask with boxes that were a gradient of semi-transparency, making the bottom most letter the most colorful and the adjacent top letters more faded. I put THAT into another particle folder that would drop these columns of text across the screen at random, and there you go. Study the file, if you can - it can explain better than I'm able to.
Here's a short video I rendered from the file: http://mfi.re/watch/5kajw3zwqoc2pge/Mat ... Effect.avi
If you want specific words to be spelled out vertically by the dropping letters, your best bet is to create a switch layer that loops the appropriate letters, then put that in a particle layer that drops the letters at appropriate intervals, velocities, etc. I guess then you could add a frame-based motion blur, and you'd have the same dropping letter effect with fading, except this time you can spell out what you want with it.
Best wishes.
Best wishes.
Ok, that explains why I couldn't find it!
Thanks a lot for that.
New matrix text effect.
And a closer look at a single line:
9.5 file: https://dl.dropboxusercontent.com/u/536 ... effect.zip
Warning, this file takes forever to render.
I hadn't even seen this!
That's absolutely brilliant Synth!
By the way, I couldn't download the file from filedropper.com. Any other links available?
I've updated the above link.
