Antializing
Antializing
Is there a way of turning off or controlling antializing in AS
EDIT: It's ok,...found it in export animation settings...
I wonder why AS does not display an unantialized image in the render display panel when it's turned off????
Is this a bug?
Cheers
D.K
Is this a bug?
Cheers
D.K
Wow!!! I never knew about the f5 preview!!! Thanks....
The preview I was referring to is is ctrl/r. There is antializing on it when it is set to off on the animation export options.
The f5 preview is a bit small to tell if theres antializing there or not. Funny I never knew about the f5 one....AS is so quick to render it never occurred to me that there should be a movie preview function.
D.K
D.K
Greysnarthur
Antialiasing
Whilst trying the F5 preview, I hit command-F5 and got the voice over!
What is the thinking behind that? Can anyone say?
- Lost Marble
Re: Antialiasing
That's a MacOS thing, not an Anime Studio thing - you'd have to ask Apple.Greysnarthur wrote:Whilst trying the F5 preview, I hit command-F5 and got the voice over!
Just to clear something up: the settings you get with Export Animation, like antialiaing on/off, shape effects on/off, layer effects on/off, etc. all apply to just the animation you are about to export. They have no effect on the File->Render command - that command always runs with the default settings. However, maybe there should in fact be a tie-in between the two.
