Hi everybody,
I'm looking for the file stack.lua which was posted a few years ago on this forum by poetbeware
It's a script to animate the stack order of shapes in a layer.
The link is dead so.... anybody got this script?
regards,
Maarten
animatable shape stack order (poetbeware)
There is a HUGE download link for a whole pile of scripts. I will be trying to go through these and put them into some kind of logical order at some point. When I get a chance I will post this script for download.
For now here is the text of the script. Copy this, paste it into a text document and save it as "stack.lua" and you are good to go:
I tried using "size" so this doesn't take up so much space but apparently it doesn't work with the "code" tag.
function pj_findStackSwitch(moho)
local current = moho.layer
local targetName = current:Name().." Stack"
local parent = current:Parent()
if (parent == nil) then
local doc = moho.document
for i=0,doc:CountLayers() - 1 do
if (doc:Layer(i):Name() == targetName) then
return doc:Layer(i)
end
end
else
for i=0,parent:CountLayers() do
if (parent:Layer(i):Name() == targetName) then
return parent:Layer(i)
end
end
end
return nil
end
function pj_extractShapeNames(fileName, layerName)
if (fileName == nil) then
print("Nil fileName!")
end
local f = io.open(fileName, "r")
if (f == nil) then
if (pj_global_filename == nil) then
return nil
end
f = io.open(pj_global_filename, "r")
if (f == nil) then
return nil
end
else
pj_global_filename = fileName
end
local line = f:read("*line")
local results = {}
while (true) do
-- If EOF, return.
if (line == nil) then
f:close()
return results
end
-- If the line says layer_type 1, then it's a definition
-- of a vector sublayer. See if it has the shapes we want.
start,finish = string.find(line, "^%s*layer_type 1$")
if (start ~= nil) then
pj_processVectorLayer(f, results, layerName)
end
-- Otherwise, if the line starts with layer_type, then it's
-- some other kind of sublayer. Recurse.
start, finish = string.find(line, "^%s*layer_type")
pj_processLayer(f, results, layerName)
end
end
end
function pj_processLayer(f, results, layerName)
while (true) do
-- If EOF, return.
return
end
-- If the line contains a single }, it is the end
-- of the layer structure; return;
local start,finish
start,finish = string.find(line, "^%s*%}$")
return
end
end
start,finish = string.find(line, "^%s*layer_type")
end
end
end
function pj_processVectorLayer(f, results, layerName)
while (true) do
-- If EOF, return.
return
end
local start,finish
return
end
-- FIXME: I am assuming that Vector Layers have no child layers.
-- Check if assumption is valid.
-- If the line starts with name, then it's the layer's name.
-- Check to see if the layer's name is the same as the
-- given layerName. If so, we need to scan this layer for
-- shapes.
local name
start,finish,name = string.find(line, "^%s*name \"(.-)\"")
if (name == layerName) then
pj_processShapes(f, results)
return
end
end
end
end
function pj_processShapes(f, results)
while (true) do
-- If EOF, return.
return
end
-- of the layer structure; return.
local start,finish
return
end
-- If the line starts with "shapes" then
start,finish = string.find(line, "^%s*shapes ")
pj_processShapes2(f, results)
return
end
end
end
function pj_processShapes2(f, results)
while (true) do
-- If EOF, return.
return
end
local start,finish
return
end
-- If the line looks like this...
-- "shape1" true false false false
-- ...then it is finally, finally the name of a shape!
local name
start,finish,name = string.find(line, "^%s*\"(.-)\" %a+ %a+ %a+ %a+")
local last = table.getn(results) + 1
results[last] = name
end
end
end
function pj_findShape(layer, mesh, name)
for i=0,mesh:CountShapes() - 1 do
if (mesh:Shape(i).pj_name == name) then
return i
end
end
return nil
-- idTable = pj_global_shape_id[layer:Name()]
-- if (idTable == nil) then
-- return nil
-- end
-- nameTable = pj_global_shape_name[layer:Name()]
-- if (nameTable == nil) then
-- return nil
-- end
-- local i = 1
-- while (nameTable[i] ~= nil) do
-- if (nameTable[i] == name) then
-- for j=0,mesh:CountShapes() - 1 do
-- local x1 = mesh:Shape(j).fName
-- local x2 = idTable[i]
-- x1 = tostring(x1)
-- x2 = tostring(x2)
-- if (x2 == x1) then
-- return j
-- end
-- end
-- return nil
-- end
-- i = i + 1
-- end
-- return nil
end
function pj_getShapeNames(moho)
local mesh = moho:Mesh()
local shapeNames
shapeNames = pj_extractShapeNames(moho.document:Path(), current:Name())
-- local idTable = {}
if (shapeNames == nil) then
return
end
local i = 1
while (shapeNames[i] ~= nil) do
-- local n = mesh:Shape(i - 1).fName
-- idTable[i] = n
mesh:Shape(i - 1).pj_name = shapeNames[i]
i = i + 1
end
-- pj_global_shape_id[current:Name()] = idTable
-- pj_global_shape_name[current:Name()] = shapeNames
current.pj_shapes = true
end
function LayerScript(moho)
local stackSwitch = pj_findStackSwitch(moho)
if (stackSwitch == nil) then
return
end
stackSwitch = moho:LayerAsSwitch(stackSwitch)
-- if (pj_global_shape_id == nil) then
-- pj_global_shape_id = {}
-- pj_global_shape_name = {}
-- end
-- if (pj_global_shape_id[current:Name()] == nil) then
-- pj_getShapeNames(moho)
-- end
if (current.pj_shapes == nil) then
end
local value = stackSwitch:GetValue(moho.frame)
for w in string.gfind(value, "([%a_]+),") do
local id = pj_findShape(current, mesh, w)
if (id ~= nil) then
mesh:RaiseShape(id, true)
end
end
end
- Víctor Paredes
It controls shape ordering inside a vector layer using a switch layer as a sort of look up reference.
The layers inside the switch don't really have any content. The names of the layers are the names of shapes in the order you want them. So you can change the order of shapes in another layer by selecting different layers in the switch whose name tells the script what order the shapes are in.
I don't think I ever used it myself.
