Importing videos with SOUND?
spoooze!
Post by spoooze! »
Hey guys,
I am trying to import some sound videos into Anime Studio Pro so I can animate over them.
How do I do this? Every time I import the videos they are silent.
I tried importing the sound separately but no luck... the video goes out of sync.
Any suggestions? I am stuck.
Out of sync within AS? If so, playing movies in AS is performance intensive, but it should be synced once rendered.
Sound in video is not supported. If the sound imported separately is out of sync with the video then make sure that the FPS of the AS file is EXACTLY the same as the video.
Sound in AS is independent of frame rate (fps). If the video is 30fps but the AS file is 24fps then the audio brought in as a sound track for the AS file will not be in sync to the video. Change the fps of the AS file to match the video and it will match up.
Video imported to AS is a "1 to 1" relationship. 1 frame of video is 1 frame of animation in AS.
spoooze!
Post by spoooze! »
^^Ah, gotcha. I'll check that out.
How do you change the framerate in the AS file?
Project settings.
spoooze!
Post by spoooze! »
Okay. Got the problem fixed. Thanks for the help!
