Does anyone reccomend using a Tablet?
Live the Dream
I'm finding it difficult to draw in Anime Studio- and think using some kind of Tablet might help me quite a bit...
Does anyone else use a Tablet?
Are they easy to use?
Can you use them in Anime Studio?
- funksmaname
I'm with him -- I have a tablet but I much prefer "drawing" in AS by taking a basic shape and adding vertices to it.
Freehand drawing is the pits for a number of reasons, not the least is the vast amount of vertices you'll end up with (no matter what your settings it won't be as efficient as moving a point and adjusting the curve on your own). If you lived near me I'd give you my tablet to try, because the odds are that within a week you'd give it up.
Live the Dream
Wow- a varied reaction...
mkelley thanks for the offer but I live in Plymouth- UK!
I'm intrigued as- I'm finding it difficult transferring my drawings into AS- I feel that its really time consuming and hard to get them to look in my sketch pad...
I've been drawing them on paper- scanning them and then drawing over them in AS- kind of like tracing- but still its taking quite awhile.
What Kind of Tablet would people recommend? I've seen some relatively cheap ones on ebay for £25
- Víctor Paredes
My life changed when i bought a tablet. I really recommend you to use one, even when you won't be drawing with freehand, it's all faster and better with tablet (anyway, don't put your mouse in the trash, just let it close to the tablet, so you can switch between each one).
now I have a ibm tablet pc, and it's even better
Live the Dream
- funksmaname
I use a tablet and a tablet pc, never owned a computer without one, otherwise I couldn't draw, it's great for drawing.
HOWEVER , anime works terribly with it and I always go back to mouse solely for ASPRO ,(unless I use the pen tool- which could work a lot better) I should really customise for ASPRO with both the wacom and tablet pc the default set-up is way to twitchy and frankly a pain.
I totally agree with synthsin and funk
Just to try and clarify the divergent opinions you're getting here, I truly believe the difference is whether, right now, you use the freehand tool or not.
A tablet (and I have a *very* nice one) is great for bitmap art where vector points aren't an issue. With vector, and more particularly, with AS, the fewer points you have to make your shape the better. The better it will deform, the better it will animate.
No matter how you set the freehand tool it's almost impossible to get it to draw efficiently -- your best bet is to use it to draw and then use a script to reduce points but even then you'll never get the precision you can achieve by adding points.
However, even those here who use the freehand tool (and like it) should at least TRY using the "skulpt" method of drawing. I first read about this in an AS tutorial (still online at SM) and it immediately made perfect sense to me and I've never looked back. Whether you are tracing or creating original art, this method is so organic and natural that it may open your eyes to a completely different way of drawing.
You can, of course, use a tablet as essentially a mouse pointer, but that kind of defeats the whole point of one. I used to do this (which is why I bought the nice tablet) with Illustrator, but one day I was traveling and didn't want to bring the huge tablet with me and lo and behold found out the mouse was FAR more efficient (like with the pen tools). However, I do think a tablet PC or the Wacom Cintiq *might* be an exception to this rule. I've never used one, but it seems like pointing directly to the screen should be easier. Before I spent the $$$ I'd sure want to try it out, though (and by try I mean at least a week).
Which brings me to one last thought -- if you're not sure and can't borrow a tablet to try, just buy something dirt cheap and then you'll know. Even the $79 Wacom Bamboo is a very nice tablet nowadays, and if after using it for a few months you think that's the way to go you can always get a larger tablet with more features and give this one to a friend or relative.
I use the tablet in AS very often. But I have a Cintiq 21" ... which makes a huge difference.
When I still had a Wacom A5 tablet I used it only for bitmap work, and not for drawing but colouring and stuff. I never used it for vector stuff like Freehand because I couldn't grab points as precisely as with the mose because of the "slippery" tablet surface.
Now the Cintiq's surface isn't any different, but the bigger size makes a big difference! Plus over the years the resolution of tablets has been increased dramatically.
My drawing style in AS is quite loosely, with the freehand tool first, then erasing a part of the points by hand. This is fast work with a tablet. And I don't have to be perfect: there's no rule about the ideal number of points on a shape. As long as it's enough it doesn't hurt to have some more.
