Mouths and two switch layers approaches
dueyftw
Post by dueyftw »
OK, I like to use more than one vector layer when a make a mouth. I like to use highlights on a second layer set with a soft edge effect and a lower opacity. The problem is that is a group of layers can’t use interpolate sub layer because their is more than one. But if group the highlights in one layer and the mouths in another switch layer they will interpolate. It’s a little extra work animating but worth it.
Dale
why can't you just put the highlights shapes on the mouth layer? You can still use soft edge and lower opacity then you only need one switch layer. The only trouble might be with "bleed" of the soft edge fill in the highlights.
dueyftw
Post by dueyftw »
You right, I like to use different layer on drawing different type of things. I would other wise be using the soft edge effect when I need a hard edge. So all I need to do is to copy the highlights layer and past it into the mouth. Then a much better approach for me is to draw in the separate layers and combine them into one. I could shut off the visibility of the other layers once combine, keeping the others as a reference. Then deleting them once happy at the end result.
Dale
Yet one more script idea that has been in the back of my head...
A "combine layers" script. Combine multiple vector layers into one layer. Conversely a script to "split" shapes on one layer into many layers... trickier if they are "connected".
Dang I love this program. Never ending options to improve it.
rylleman
Post by rylleman »
There is an old Switch slave script which you can use so your second switchlayer mimics your first one. That way you only need to animate the main one and forget about your highlights.
viewtopic.php?t=2506&highlight=switch+slave
O.T. >Heyvern, add a "send selected shape to a new layer". Would be very useful. Create your character in one layer and then start splitting it into different layers.
dueyftw
Post by dueyftw »
I'm now connecting each object (highlight) with a hidden line. That way I can remove the layer that I copied and paste by just grabbing one point and then using select all to remove it.
Dale
