Core dump on linux
jorgy
Core dump on linux
Post by jorgy »
Fedora core 3, while clicking in the Actions window. Here is a backtrace:
#0 0x0819b885 in AnimChannel::Duration ()
#1 0x0819b8ea in AnimChannel::Duration ()
#2 0x0819b8ea in AnimChannel::Duration ()
#3 0x081a38bc in AnimVal::InsertPose ()
#4 0x081d8544 in MohoLayer::InsertPose ()
#5 0x080be29e in ActionWnd::HandleMessage ()
#6 0x08160a56 in LM_Layer::HandleMessage ()
#7 0x081664dc in LM_View::HandleMessage ()
#8 0x0815fb82 in LM_Handler::SendMessage ()
#9 0x0815fb47 in LM_Handler::SendMessage ()
#10 0x0816fa76 in LM_Button::OnMouseUp ()
#11 0x0816762a in LM_View::_OnMouseUp ()
#12 0x081616be in LM_Layer::OnMouseUp ()
#13 0x08168bab in LM_Wnd::OnMouseUp ()
#14 0x0816afe9 in LM_Wnd::PlatformKillTimer ()
#15 0x415da757 in gtk_marshal_VOID__UINT_STRING ()
from /usr/lib/libgtk-x11-2.0.so.0
#16 0x412e1347 in g_closure_invoke () from /usr/lib/libgobject-2.0.so.0
#17 0x412f7ae1 in g_signal_has_handler_pending ()
#18 0x412f8913 in g_signal_emit_valist () from /usr/lib/libgobject-2.0.so.0
#19 0x412f8f5a in g_signal_emit () from /usr/lib/libgobject-2.0.so.0
#20 0x416ce545 in gtk_widget_activate () from /usr/lib/libgtk-x11-2.0.so.0
---Type <return> to continue, or q <return> to quit---
#21 0x415d8a1b in gtk_propagate_event () from /usr/lib/libgtk-x11-2.0.so.0
#22 0x415d8d20 in gtk_main_do_event () from /usr/lib/libgtk-x11-2.0.so.0
#23 0x417c10a2 in gdk_event_get_graphics_expose ()
from /usr/lib/libgdk-x11-2.0.so.0
#24 0x4127e7bb in g_main_context_dispatch () from /usr/lib/libglib-2.0.so.0
#25 0x41280242 in g_main_context_acquire () from /usr/lib/libglib-2.0.so.0
#26 0x412804ef in g_main_loop_run () from /usr/lib/libglib-2.0.so.0
#27 0x415d807e in gtk_main () from /usr/lib/libgtk-x11-2.0.so.0
#28 0x0815eeb8 in LM_App::Run ()
#29 0x080f98a8 in LM_Main ()
#30 0x0815d360 in LM_App::Main ()
#31 0x0815e722 in main ()
Would you like the corefile and the .moho file to debug? I don't have the exact .moho file because, well, moho crashed and I had made lots of changes.
Thanks,
jorgy
Lost Marble
Post by Lost Marble »
No thanks - don't want the core file. Which version of Moho are you using? You can find out with the Help->About Moho menu command. Version 5.0.8 had a problem with certain actions that this could be related to. Version 5.0.9 should have fixed the problem. You can find out more about 5.0.9 here:
http://www.lostmarble.com/forum/viewtopic.php?t=1095
jorgy
Post by jorgy »
I am using 5.0.9. :shock:
