Making Water and splash,
Skullfire
Post by Skullfire »
I'm kinda new at Anime Studio. Specially on particles. I need to make a sea, lake or big water, and a man jump into it and splashing water. So, I dont know how to make realistic water and splash with particles. Can u pls help me, because if I do this I will almost finish my animation for my school. :(
Nolan Scott
Post by Nolan Scott »
Well, if you like, you can download the file “splash.anme” from my iDisk:
http://homepage.mac.com/nolan.scott/
This is just a very simple example to start with...
You might like and change the shape and colour of the particles to fit your needs...
Or change the settings altogether...?
Creating some movement in the “water-layer” maybe animating some colour-vector-shapes would be nice as well...
Cheers
Nolan
luisba
Post by luisba »
Hello Nolan
I have tried download you file but it say "this file is from a newer version of moho" I have Anime Studio pro. Could I get another way?
thanks
Here you go Luisba. I fixed this one to work with older version.
http://www.mediafire.com/?inajd1v7efw
If you're using a version of AS older than 5.6, you'll need to edit the text file to open 5.6 files. Here's how you can do this yourself.
Open it with Notepad.
Change the version at the top:
application/x-vnd.lm_mohodoc
version 15
So it reads:
version 14
Then go through it (using Edit>Find in Notepad) and delete the layer ordering data. So you would take this:
### bone layer values
	expanded true
	group_mask 0
	depth_sort false
	distance_sort false
	layer_ordering
		keys 1
			0 1 0.1 0.5 ""
	skeleton
		binding_mode 1
		bones 0
And make it look like this:
	expanded true
	group_mask 0
	depth_sort false
	distance_sort false
skeleton
      binding_mode 1
      bones 0
Save and open in AS 5.5 or older.
:wink:
