Hello!
i'm missing something really easy I guess, since I didn't find the solution in the forum.
I have an animation of a bitmap with bones, but when I export it, i cannot see the bitmap... And when I save the project and send it to someone he cannot see the bitmap neither.
Which checkbox did I miss?
export animation with bitmap
- Lost Marble
Are you exporting as SWF (or what format)? SWF is not capable of warping images the way Moho does with bones, so warped images cannot be exported to SWF. Also, SWF only supports certain image formats - what format are you using?
When you send the Moho file to someone else, be sure to include the image(s) you use. These do not get embedded in the Moho file, Moho only retains links to the separate files, so if you send a .moho file without the images, the other person will see broken image icons.
- Lost Marble
Hmm, can you send the BMP file to support@lostmarble.com? Or post a link to it here in the forum?
