I need to find an efficient way to change a body image so that the character can rotate then return to its original position. That would require to hide the original body and show a different one that's turning using the same skeleton. I can't figure out how to do so.
seen here: viewtopic.php?t=12157
switch avector image with multiples bones
That sounds like it'll work. It all depends on how you work. I'd be more apt to do an animated action for the turn, but for quick enough motion a switch should work fine.
Complex questions like this are always difficult to answer properly. I always want to make up an AS file to illustrate the options, but that would take more time than I can spend on these things. If the file in question can be shared (i.e. not commercial work) then people have a starting point to show solutions.
Just an option.
Just an option.
