Moving all keyframes within a group layer or multiple layers
Hello there...
Is it possible to move all the keyframes on several layers or inside a group layer at once?
I have a group layer with about 20 different layers of animation. I need to move all keyframes back in time. Can i select everything at once somehow?
This would help me out a lot.
cheeeeeeeeeeeeeers,
Bisagaboo
cheeeeeeeeeeeeeers,
Bisagaboo
- funksmaname
Try this:
1) Make a back up of your files
2) Set the layers you want to move the keyframes inside a root folder. Give it a meaning name. Save the anme file (*).
3) Create a new empty file. Import from the (*) file and select the root folder you want to move the keyframes.
4) Using the Rescale Keyframes menu command do a full document rescale keyframes to the position you want. Save the file (**)
5) Open the (*) file again and delete the root folder you created. Import the root folder again from the (**) file with the keyframes moved.
Of course (*) and (**) must have same proyect settings (size, fps, etc.)
Good luck
Good luck
Something else you could do (assuming you have the Pro version) is create an action at a top master group layer and copy from the main timeline. This will have all the stuff from the lower layers in it. Then erase all animation from the main timeline and, at the top group layer, use the action wherever you want (either as a copy or as a reference).
I actually do this all the time (but not for the reasons you are looking for -- I create all my actions by doing them on the main timeline first).
Thanks heaps for the info.
I went with the rescalling a new document option as I'm still a bit unfamiliar with the whole actions thing.
Either way it worked like a treat and saved me a lot of time, so cheers everyone. I'll keep the action thing in mind aswell....it sounds intriguing...
thanks again
bisagabooooo
thanks again
bisagabooooo
- funksmaname
just to touch on something synth said - i make my actions in the action palette, but;
a) create the cction while the group is selected - this creates the action for all layers below
b) i've installed a script that makes the letter 'J' go to the parent layer, and as long as you go to the parent layer then back down to another layer you dont get knocked out of the action... so i press J, then just select the next layer i want to work on in the action. (pressing J is easier than copying keyframes from every layer!)
i dont remember what script it is, but a search of the script forum should find it!
Re: Moving all keyframes within a group layer or multiple la
Anything new on this in the last 7 years. It's kind of a stick in the eye.
- Víctor Paredes
Not officially, but you can try this fantastic script:
viewtopic.php?f=12&t=13935
Also, at least for me, Smart Bones have fixed many of the multi-layer editing problems I had. I know I'm not talking about the specific feature asked here (which really needs to be implemented), but they help to keep many layers' keyframes inside one single bone.
Thanks for the help. And yes, I am told the wise always animate on the bones … sigh, here and there it was so easy not to.
And thanks for the link to the script. It seems you have to add a line or two of code to make it work with AS11. I'm just getting comfortable with python (an ill conceived ungainly hybrid and I think my 9th computer language since FORTRAN IV) and not knowing Lua and remembering the halcyon days of scheme and Common Lisp I shed a tear, closed the page and told myself “I'll look at it tomorrow.” And I will.
Again thanks,
DeCay
Again thanks,
DeCay
Am I wrong, isn't this something you can do in the sequencer?
