Import Image Sequence Script Solved
DK
Post by DK »
Hi.
I was using the Import Image Sequence script today and found that when you import an image sequence, the script renames your images to create it's own image sequence nameset. That's fine except when you want to adust one of the images slightly in an image editor then the problem is you cannot refresh any of the image as they have been renamed. You have to completely delete all images and re-import them...in my case I lost all my tweaked cycle keyframes and had to start from scratch. Just wondering,if it iwere possible anyone on the list could take a look at it?
Cheers
D.K
Hey DK,
it is not a problem of the script. Forget the names it gives to the imported layers. The correct path to the file is there, inside the layer properties. The problem is that AS doesn't have a "refresh" images sources button. As you know, for fast render, images are stored in memory so you cannot update the touched original image file(s) until you don't close AS open it again and load the anme file that has the image sequence imported.
DK
Post by DK »
Hi Genete.
Thanks for that. ....now I remember this problem giving me headaches before and having to save changed images in a sequence to new filenames just to get them to import as this was faster than closing and re-opening the file constantly.
Thanks for the explanation Genete ;)
Cheers
D.K
Let me give you a present:
-- Provide Moho with the name of this script object
ScriptName = "GE_reload_image"
GE_reload_image = {}
function GE_reload_image:Name()
	return "Reload Image"
end
function GE_reload_image:Version()
	return "1.0"
end
function GE_reload_image:Description()
	return "Reload image form disk"
end
function GE_reload_image:Creator()
	return "Carlos López (Genete)"
end
function GE_reload_image:UILabel()
	return "Reload Image Source"
end
-- The guts of this script
function GE_reload_image:IsEnabled(moho)
	if (moho.layer:LayerType() == MOHO.LT_IMAGE) then
		return true
	end
	return false
end
function GE_reload_image:Run(moho)
	local l=moho.layer
	if(l:LayerType()~=MOHO.LT_IMAGE) then
		return
	else
--		print("reloading...")
		l=moho:LayerAsImage(l)
		local fname = l:SourceImage()
		l:SetSourceImage(fname)
		return
	end
end
save the script, name it ge_reload_image.lua and save in the menu>scripts>layer folder
Usage: select the image layer that you have modified and run the script.
Enjoy
DK
Post by DK »
Hi Genete
Wow....thank you for doing that.
I am getting an error though and can't run the script to test it.
Cheers
D.K
DK
Post by DK »
Hi Genete.
I fixed it by removing the two top lines with the "*******"s ...there must be a typo in there somewhere. Seeing this is your script I will wait for you to fix it properly and re-upload it and then I will replace my hacked one.
YAAAY!!!! This is a BRILLANT script....It works like a dream!!!!
Thank you so much Genete!!!! :)
D.K
Yeah! It was my mistake during the copy/paste sequence. I think it is fixed now.
You're welcome :)
(Didn't anyone do this script before???? ... sure?. If only LM would add a right button context menu on the Image layer to do this... )
DK
Post by DK »
I placed it in the same menu as the "Import Image Sequence" script so I'll always know it's there. I will use this script a LOT.
Many thanks again Genete.
Cheers
D.K
If you want to make a short cut or a button just copy it to the tool folder and add a line to the desired section of _tool_list.txt file:
button ge_reload_image    +
You should reload the script from the post above. I've modified it to make it available only if a image layer is selected.
Of course copy the script to the script/tool folder and provide a cool icon :).
I've found that the '+' key is not assigned to any task. I think that LM didn't assign them for different keyboards compatibilities. But I believe that you can assign any "typeable" character from the keyboard.
Enjoy!!!! :D
Yes, I think there was an earlier script that did this. It was done a long time ago, back in the "Moho days"... before I even bought Moho I think. I have no idea who did it or where it is... and I'm too lazy and tired to look for it. ;)
